ANSI Flange in the January 2nd "What's New" video about configuration?
Where can we find the ANSI Flange used at the end of the January 2nd "What's New" video about configurations:
https://forum.onshape.com/discussion/7975/improvements-to-onshape-january-2nd-2018/p1
THANKS
THANKS
NeilCooke Moderator, Onshape Employees Posts: 5,848
Thought I'd made that public - it is now. Although the sizes are based on the spec (from a supplier's website), it doesn't include every permutation. I used this as an example to see how far I could push configurations to be more like a configurator.
https://cad.onshape.com/documents/36d5314a70153cbd63de384f/w/ecc6d196a635c11c03cad1c8/e/880b4fac43003796ddcb1b97
Senior Director, Technical Services, EMEA7
Excellent example of pushing configuration. Impressed by using derived Flange in the elbow's configuration!
Good news, Onshape has automatic part numbering built-in already! If your organization has Release Management turned on, you can define part numbering schemes, and then assign part numbers from a release package, from the part properties of a part, or even from a BOM in an assembly.
Short video:
https://www.onshape.com/videos/release-management-and-approval-workflows
Webinar:
https://www.onshape.com/videos/introducing-release-management-and-approval-workflows-040518
