How to edit bill of materials?
Allen_ProsserAllen_Prosser Member Posts: 1 PRO
My bill of materials is displaying a duplicate of the same cable because it is modeled as different lengths. Is there a way to edit my bill of materials to show the correct info without modifying my 3D model?
  • john_mcclaryjohn_mcclary Member, Developers Posts: 3,981 PRO
    Technically they are in-fact different parts, and should appear as two line items.
    You can do this for a work around:
    exclude 1 of the two instances from the bill of material by right clicking it's instance in the BOM flyout.
    Then add any notes to accommodate for length/qty in the description of the part.
    or you could add a dumb part (3) or so times (whatever qty you need), then set it's properties to be cable.
    then exclude all of the actual cables.
    Yea, I know it's not the best, In solidworks we could just exclude all the other parts. Then override the qty directly in the BOM.
    But either way, overrides are bad
    You can edit the Workspace or Version properties
    Un saludo,
