How do I solve this problem from Fundamentals 3 - Exercise: Step slide 12-13?
johnny_tranjohnny_tran Member Posts: 2
I have been following step by step with the exercise then at those slides. When creating a linear pattern from Rib 1, it also include the face that was selected during creating the Sketch 2. How do isolate the rib from the additional face?
Link to document: https://cad.onshape.com/documents/edff21d61bfaadfe779927a4/w/add78453cf3e0d1ff60f2fc4/e/a880aab00b76bc65c7436292
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,000 PRO
    I'm not sure what you're asking that looks like a good-looking model to me what is it supposed to look like?
    @johnny_tran
    It looks like you figured this out?  Was the problem that you needed to select "Apply per instance"?
