Is there undelete for tabs yet?
I built an object in a parts studio tab 1 with a derived part from an adjacent tab 2, then did a boolean union of those objects. Assuming I now had a single unified object I deleted the adjacent tab and the portion of my tab 1 object disappeared, I don't see a way to get it back or undo. Any suggestions?
brucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,146 PRO
Did you try restoring to the step just before the "Delete tab: Part studio"? Hopefully you have not done too much work after this, if so you could attempt a branch and merge from this point to save your work post Delete tab.
5 -
adamohern Member, OS Professional Posts: 216 PRO
Hey Tom, you should mark one of the above answers as correct so that your question will fall off the 'unanswered' list.5
