How do you dimension a diameter on a line?!
kiarian_coohill
Member Posts: 16 EDU
in Drawings
Fundamentals 3 - Exercise: Coffee Cup
Fallen at the first hurdle here. I can't figure out how to dimension this 125 diameter. It's a line. How do I go beyond the line to change the dim to a diameter?
I've read the hint, and I still haven't figured it out.
I am new to CAD and I am stuck! I cant figure out how to get the diameter on the mug, I've managed to do this one the wheel exercise but cant figure out how to do it again.
See the "centerline dimension" section of this page:
https://cad.onshape.com/help/Content/sketch-tools-dimension.htm
To do this type of dimension, you'll first want to click the dimension tool, then click the point you want to dimension, then click the centerline, then move your mouse across to the other side of the centerline, then click one last time to place it. The key here is to move your mouse across the centerline after selecting both the entity to dimension and the construction line you want to use as a centerline.
Hi calvin_george,
The trick to getting the diametric dimension is to select the construction line first, then the point you wan to be the diameter, and then to place the dimension on the opposite side of the construction line.
1. With the dimension command active, select the construction line
2. Select the outer point on the cup. This will start doing a horizontal point-to-line dimension. But don't place it yet.
3. Before placing it, move your cursor to the other side of the construction line. This will give a diametric constraint.
Thank you in advance
The selection you are using for the revolve is the entirety of "Sketch 1". You should de-select the whole sketch (space bar or clicking the x next to that selection), and instead select just the inner area by clicking on it.
I had a similar issue with the bottom dia dimensioning, I could get the top to work, ended up adding another small construction line at the bottom to get the dia dimensioning to work there.
@andrew_southen
Make sure you are in "Solid" mode, and make sure that the "Faces and regions to sweep" box is the currently selected box.
If you are in "Surface" mode, it will only allow you to select edges, because edges are swept into surfaces. If you are in "Solid" mode is will only allow you to select faces, because faces are swept into solids.
Then click on "Sweep path" and select your path.
Hope this helps!
I am an old Onshape user so this option is not unknown to me, but,
Does anyone else instead of me, have trouble with diameter measuring in the past few weeks.
The dimension just doesn't show the diameter when I move my mouse to the other side of the centerline, which is really annoying...
Is there any Problem with Onshape update, or do I miss some OpenGL update or something else???
Please help.
Thanks and best regards
About a month ago I had that problem the first time, but the next day everything was OK.
But a few days ago I had that problem again, so that's the reason I posted this.
Today it works fine again...So what to say.
A problem definitely exist. It is impossible that only I have the problem periodically with it
