Onshape as a PDM system?
I'm investigating cloud based PDM systems. Currently our company is using the Solidworks PDM system to manage our data (server based) and we use Autodesk Inventor as our main drafting program. We have a large repository of legacy data (around 300k drawing files excluding Inventor files), mostly PDFs but also other file formats such as xls, tiff and other image formats, and of course DWG. We also have a large amount of Inventor files. Our reason for looking at moving to a cloud based system is to reduce (eliminate) the software and server maintenance issues. The document control possibilities of a cloud based system are also very appealing. Our company is currently moving from the standard Microsoft office suite to the cloud based Google suite for general office software, so the mindset is there to make this happen.
Moving over to Onshape would be no small undertaking, I think. Although the Onshape site appears to offer a large amount of educational material, I don't have the time to wade through it all and I'm struggling to understand how Onshape would look as a replacement for our current PDM system and how difficult it will be to migrate our data over to Onshape, including conversion of Inventor files. I'm appealing to the user forum in the hope that I can get some answers as my attempts so far to contact Onshape directly have been fruitless.
My Questions:
1. As a PDM system, how does Onshape compare to something like Solidworks PDM or Autodesk Vault? I'm assuming that as far as document control goes, Onshape should be brilliant compared to the cludgy server based system that is still copying files around over the network, but what is the reality for users?
2. For a user not interested in drafting, but only viewing files, what does Onshape look like and how easy is it for a new, non drafting savvy user to pick up? One of the things we liked about the Solidworks PDM is the familiar Windows like use interface.
3. How easy will it be to migrate our existing legacy data over to Onshape? How long will it take and can Onshape migrate all of the existing metadata in the currently in the Solidworks PDM?
4. Can we migrate our existing Inventor files and use them in Onshape? I assume that existing part files would be translated as dumb solids, but are there any smarts that can make them more useful?
5. Network performance could be a big issue here as our internet is not always 100% reliable. Is that a deal breaker? What are user experiences with cloud based CAD with regard to reliability?
My Questions:
I spent too many hours at my previous job waiting for files to sync from a PDM system to ever invest in one.
I hope that helps.
CAD Engineering Manager
2. Onshape is extremely easy to use for a view only purpose. They are able to navigate the file and view everything in the document without changing it. I would say only minimal training if any is required for view only purposes. Each user can be set up with differing levels of permissions.
3. The existing metadata will not be migrated over. My recommendation would be to only migrate over the active files or on an as needed basis. Trying to rebuild everything that you have currently would take a considerable amount of time and effort. Also, you may decided to change your standard operating procedures after using Onshape for a while. Therefore I would be hesitant to just migrate everything over and essentially try to copy what you have currently.
4. Yes Onshape is very capable of importing many different file formats. As you assumed you will just get the solid without any of the parametric data that was used to build it. However, Onshape does have powerful direct modeling tools built in that will allow you to modify the solid as needed.
5. I would say if you are already transitioning to cloud based software than a reliable and high speed internet connection is going to be needed. There is no offline working version of Onshape so it is critical that you have a good internet connection. I would say that this is important for operating a business in general in today's day and age and not necessarily specific to Onshape.
I have been using Onshape professionally and as a hobbyist from essentially the beginning. It is a very powerful CAD package and I believe that it will eventually incorporate the entire design process and eliminate the need for many third party softwares. It is a new way of thinking and I would highly recommend going through the Onshape fundamentals training courses. They are free and it takes 5 to 6 hours to work through all of them. This will be a good introduction to the capabilities. After that you really need to use the system and find a process that will work best for your company.
https://www.onshape.com/cad-blog/introducing-design-data-management-2.0
When will that be released?
Is that new Design Data Management 2.0 only available for Pro Users and not for FreePlan Users?
In the video it looks like it is only available for companies.
1) There is currently no preview for PDFs. Is this on the radar for future inclusion?
2) Although there are quite a few default property fields and the ability to create custom properties. However, it doesn't appear that you can search for anything more than name, description, part number and revision. What is the point of having all the additional properties if you can't search on them? Are there any plans to improve the search tools?
3) Zooming and panning the PDF within the document is buggy.
1) What do you mean by 'preview'? Yes you can upload PDF's. Yes you can view them.
2) Malcolm, yes! You absolutely will be able to search by custom properties. I believe the expression is 'coming (very) soon!'
3) The mechanism we are using is 'browser preview'. All of the Onshape-supported browsers have a PDF viewer build into them.
- What browser are you using?
- What 'bugs' are you seeing?
The data management capabilities built into Onshape are quite sophisticated, please let us know if your company would like a one-on-one tech session with a pre-sales application engineer.The bug I was seeing was with the zooming, panning and scroll bars not working, however I haven't been able to reproduce it, so it may have been a browser issue.
