Dimensioning Springs
StephenGStephenG Member Posts: 383 ✭✭✭
I have created a 3D model of a simple helical compression spring and I cannot figure out how to a dimension a drawing documenting its overall (Free/Compressed) length and OD/ID if I have to dimension to silhouette curves.
The dimensioning tool in OS Drafting does not like silhouette curves which is understandable, but there is no way to add center/alignment lines to silhouette curves to allow dimensioning.
    Create a sketch, showing the overall length, then in the drawing, update, then right click on the view and choose show sketches. Choose the sketch you just created, then dimension to it
    Philip Thomas - Onshape
  • StephenGStephenG Member Posts: 383 ✭✭✭
    @mbartlett21 your suggestion is a clever work around. I added additional construction curves representing the OD/ID/Height envelope of the spring to the wire profile sketch and made the sketch visible in the drawing view, then created the dimensions to the construction curves. I found that I needed to use variables to coordinate the sketch and helix curve heights. Thanks.
