How to rotate the sketch coordinate system of a part that was generated by in-context editing
I have a simple rectangular plate. It was generated for the first time by in-context editing of an assembly. That assembly had some items angled at 45 degrees, and somehow this plate picked up that coordinate system. So if I draw a new square in a sketch for this part, it is oriented at 45 degrees to how I want it. It is possible to change the base coordinate systems so that subsequent sketches are along x', y', z', not x,y,z? I tried Transform, and this sort of works: it only transforms the part, so new sketches are in the correct orientation. Unfortunately, old sketches are left unrotated, and hence not useful for reference.
thanks, John
thanks, John
NeilCooke Moderator, Onshape Employees Posts: 5,868
@john_P37 - the first option should be to create a mate connector on the angled face in the assembly before creating a part in-context (rather than using the assembly origin), then the new part will then be in the correct orientation in the part studio. The second option would be to create a construction sketch on the face of the plate, then create a plane through that sketch so that the plane orientation is correct. Hope that makes sense.
Third option is to create a mate connector on the face in the correct orientation, then use this custom feature from our very own @Jake_Rosenfeld
to create a plane through it. Then sketch on that.Senior Director, Technical Services, EMEA6
As always, a link to a document gets you the fix
Here was my trial:
https://cad.onshape.com/documents/d02ba027632901ed5aaff6ef/w/04905dfb7cbb3d58f4afe89f/e/4d90f69d752ec97fe4f9600c
Best regards,
John
(i will see what i can do
Yes!
No need for an IR for this one -- it's actually already being worked on.
I know you're kidding, but I'll respond seriously regardless -- please don't filter suggestions assuming someone else may have already thought of it! That's how great ideas get lost.
Yes - as of the PREVIOUS release, you can use the z axis of a mate connector as the axis for any pattern/transform.
WIth THIS release, you can now define the xy coordinate system of a sketch by using the mate connector to define the sketch.
One Connector to rule them all!!!
Hopefully in due time...
https://forum.onshape.com/discussion/9943/part-studio-the-ability-to-transform-move-parts-by-inferred-mate-connector#latest
https://forum.onshape.com/discussion/9936/sketching-make-the-centroid-inference-snapping-relations-easier-discoverable-i-e-mate-connector#latest
Ogden S. (Damn predictive text, but I like that one so I'm leaving it.)
