Why does my part look like this?
michael_mcewen
OS Professional Posts: 78 PRO
in General
I've drawn a part in part studio, basically a ring with flanges. It looks correct; all constraints are in order, all lines are black. After extruding, it looks faceted. Not sure why. Any ideas??
Here's the file: https://cad.onshape.com/documents/3dd0f5a01a4f3ab9946cd01a/w/0c76860cd41097ed46076413/e/ca85ec4235c0c526b256e3ec
It's the 9th part down from the top, called TOP CROSS.
The short answer is that there is a triangle budget for each part studio. Lots of parts = coarser tessellation.
There is actually more intelligence - but for now, assume thats how it works.
The ability to override the tessellation setting is just the first step - more coming!
https://cad.onshape.com/documents/3dd0f5a01a4f3ab9946cd01a/w/0c76860cd41097ed46076413/e/52d289c17f89335c0973c905
Let me see if waving my wand over this helps at all . .
Things for you to do.
https://cad.onshape.com/documents/9a78228c55a1d44862542e48/w/23c3997df919ac767a325cb5/e/a15ce866b85fbfd426c5f0f9
I hope this helps
Thanks for the tips!
If you would like a 1 hour primer on Mating Assemblies, here is a webinar i gave last week.
https://www.onshape.com/videos/onshape-assemblies-for-solidworks-users-071018
https://en.wikipedia.org/wiki/Constructive_solid_geometry
