Create multiple size rings stacked
What would be the best way to create a stack of rings (each ring is 16 different parts) with each ring having a different diameter, different height and different depth. These would be stacked then turned on the lathe to make a vase. In inventor I would make a copy of the origional then change the parameters.
https://cad.onshape.com/documents/19ccedfa79bcaae737fc2b78/w/57ef42aa3da09539b7ab6acb/e/595ed0d6e4e6dca34a193ead this is the ring I am starting with.
If you want to get an idea of what some of my finished pieces look like go to www.paul-bartlett.com
Jake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646
@paul_bartlett
Short answer: Yes
How to do it:- Set up the whole thing in an assembly
- Create a new Part Studio in-context of the assembly (there is a tool in the toolbar, or you can right click on the origin of the assembly)
- Use the "Transform" feature to "Copy in place" all of the ghosted parts from the assembly
- Do the revolve cut on the copied parts
Jake Rosenfeld - Modeling Team7
Wonderful gallery by the way!
Twitter: @bradleysauln
Short answer: Yes
How to do it:
