Bend in rolled sheet metal
bill_daniels
Member Posts: 280 ✭✭✭
Bends in flat sheet metal work great but what about bends where a rolled section transitions to a flat section? I can't seem to make that work.
Please see two examples.
If this does not help, publish a link to your document - some-one would help you.
Then I would be able to add a flange
Sometimes you will need to switch inner/outer
https://cad.onshape.com/documents/410b96f2236fdf1c3c3f53ec/w/382ea78034518f2c0ddf54ed/e/29cb2242c7f0c240dab7b042
The 3D part and the flat sheet metal seem to work in the part studio but the drawing of the flat sheet doesn't include all the bends.
Try showing tangent lines in the drawing view
EDIT: Select the arc that should be a bend in the "Arcs to extrude as bends" selection box
The manual way I can see to put this is to show the tangent lines on the flat pattern in the drawing and then make a center line between the tangents to get that bend location. I made a copy of the document showing what I did:
https://cad.onshape.com/documents/ce6d0a683e96e0ffd591886e/w/45b6a3e4130879da5170a1c9/e/b5cc1b7fb38520fbfc703ff7
When making large radius in a sheet metal part and I do not have a tool to do it on the press brake or need to make a slight bend at the tangents to note start and stop of where to roll the radius I show the tangent lines and dimension to them.
Hope this helps
Twitter: @BryanLAGdesign
The arc that should be a bend (with a bend line) should be selected in the arcs to extrude selection box when you create your sheet metal model.
Sorry, I hadn't realised
