HI, How can I enlarge a view in drawings larger than 1:1 scale?
stuart_ward055stuart_ward055 Member Posts: 10 PRO
I thought this was just a matter of changing to 1:2 in the dialog box but that doesn't work.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,806
    Try 2:1
  • stuart_ward055stuart_ward055 Member Posts: 10 PRO
    Hi Neil,
    Thanks for the quick response.
    The 1:2 was a typo sorry!  I had Tried various permutations but cant go over 1:1 scale. Could have sworn it worked before...
  • john_mcclaryjohn_mcclary Member, Developers Posts: 3,942 PRO
    edited July 2018
    there are scale up options in the drop down list also, 2:1, 3:1, 4:1 etc
    if you scroll down the list
    Just in case you may be putting a ; instead of a : :)
    HI Neil, John,
    Thanks for your comments, I opened the document just now to raise a ticket and its working as it did previously.
    Not sure why, but its not an issue now.
    best regards,
    Stuart
