Can I put dashed lines on a drawing?
I am making a drawing of a simple rectangular window. Typically, the optical properties of this window are only specified in a sub-region, specified by a dashed line rectangle. This rectangle sits inside the actual physical rectangle of the part. Is there a way to show this dashed line rectangle in a drawing? Here is a picture of what I want to do, see below. Thanks for your time. I can think of a workaround involving a feature on the back side, but that is messy, and each side has it's own clear aperture.
John
John
NeilCooke Moderator, Onshape Employees Posts: 5,856
You can create a sketch in your model using construction lines, then show the sketch in your drawing (right click view and show/hide sketches). Centerline font though.Senior Director, Technical Services, EMEA5
If the sketch is on a face that is shown in an auxiliary view, you can't show the sketch. So for a simple triangular wedge part, say a 45-90-45 degree prism, and the sketch is on the hypotenuse face, you are not allowed the option of showing sketches on this face.
Thanks for any comments, John
Sample file below:
https://cad.onshape.com/documents/176599d7c4dbeb65ef8402a6/w/06be5ce2e3cfca8b188ef4f5/e/392a7be78dae4eb17ebc6abf
It appears to work on all other types shown below
Side note: The sketch did appear on the preview graphic before placing the section view, but then disappeared once I placed the view.
I tried offsetting the sketch plane with the circle deeper into the part, and it still does not show.
If this is a bug, please add me to the ticket as well, It hasn't come up with my Onshape projects yet. But I know some of the solidworks projects I'm fighting to move over to Onshape will require this.
https://cad.onshape.com/documents/28050bca2b1ddeb0acbab720/w/72369ffa7faabbf84de28ab1/e/f86c2c0f5e11b4f730f5581c
If there's something that I'm missing, I'd be delighted to be informed.
chadstoltzfus@premiercb.com
