Exporting to .stl format
alexandra_wheeleralexandra_wheeler Member Posts: 4 EDU
Hi,
I can;t seem to export my file. I would like to 3D print it. I wonder if I have less capability as Im an education subscriber. I've followed the 'help' options, but I don;t seem to be able to do as suggested as I don;t have the features ie: I right click on the file name, and 'export' is supposed to appear, however this isn;t happenning for me? Id LOVE some tips. Im worried all my time has been wasted now. Thanks in advance!
    Please paste a link to your doc here and someone will have a look for you.
    Edu plan gets all the features so no problem there.
    Cheers,
    Owen S
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,868
    Is it your document, a document that was shared with you or a public document? If you don’t have export permissions you won’t be able to export.
  • alexandra_wheeleralexandra_wheeler Member Posts: 4 EDU
    https://cad.onshape.com/documents/215bc6b0b779eac5ef8238a3/w/238c8c1e13444cf8cba40ef7/e/9fe0e9d0193d215de3fb15e8
    The link is above. It is currently a public file. It doesn't need to be however. Neil Cooke - It was never initially a document that was shared with me however ..... I constructed it myself.
    Thanks Owen and Neil for looking at this. Im new and still finding my way. Cheers
    edited July 2018
    @alexandra_wheeler you sent a link which is read-only - the doc must be made public for anyone to copy it. Anyway it's simple enough, either right-click the part studio tab at the bottom, or right-click the part on screen or from the parts list and select export - it will be there. If not, post a screenshot of what you see.
    Thank you so much. Got it! I really appreciate your help Neil.
    Cheers
