What's The Best Way To 'Use' Then Modify That Sketch Entity?
larry_hawes
Member Posts: 478 PRO
in Drawings
Missing something simple here. I think the whole idea behind the 'use' command is that the new sketch will 'use' the lines etc. of the original sketch being used, and be locked to that original sketch via the 'use' command.
I seem to be in a bad habit of where I want a new sketch to follow exactly the shape of another sketch which 'use' seems to work great for but after drawing that new sketch I then want to alter it but the 'use' constraint prevents that, so I have to delete all the 'use' constraints then alter the new sketch.
Is there another more efficient approach I could be using?
Working up a video example and will post shortly.
OptionsJake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646@larry_hawes
A good workflow here may be to "Use" the desired geometry as construction geometry and then create new non-construction entities that reference the construction entities:
https://cad.onshape.com/help/Content/sketch-tools-construction.htm
Jake Rosenfeld - Modeling Team5 -
OptionsNeilCooke Moderator, Onshape Employees Posts: 5,400@larry_hawes I often use edges from other sketches or model edges then delete the endpoint constraint so I can extend or trim the line. Is this what you are trying to do?
Senior Director, Technical Services, EMEAI5 -
Optionslarry_hawes Member Posts: 478 PROI think using 'use' for anything other than its intended purpose is not smart intent and just a bit lazy. To achieve what I want which, in a simple example is to create a hole with a plug and have the plug be slightly smaller than the hole. I am sometimes tempted to 'use' the original hole for the plug sketch then modify the sketch but I can see that anything less than carefully measuring both the hole and the plug will never be very efficient.
So please ignore this question...doh0
i.e. I draw a circle and make a concentric constraint to an existing hole and set dimension between the circle edges to oversize the hole +1/32. Could be done with the use command, but it adds a step and leaves construction geometry that I dont see benefiting anything.
Like I said, depends on the use case. I still use plenty of 'Use' commands
Try using Extend (Keyboard shortcut: X)
