Lofting Errors
Paul_Arden
Member, Onshape Employees, Developers Posts: 164
I have spent hours trying to get a successful loft with no luck. I have tried simplified cases which end up being hit and miss but for the one I am actually trying to do I haven't been able to get anything to work. The failed loft is at the bottom of the feature list in this document:
https://cad.onshape.com/documents/6b0496e855682661004f9ecd/w/5d467c03d1f0b17cef7cd0c3/e/5ed83894eac9e781203c43aa
Here's what it looks like:
And here's the top and bottom profile:
I've put each guide into it's own sketch and added pierce constraints to all of the end points however I still get loft errors. I have tried each guide individually and I also have the same issue. I've been through the forum looking at quite a few other peoples problems with lofts but haven't found any of those solutions to work.
Any bright ideas?
Any bright ideas?
#1 problem - guides must be tangent continuous
#2 lofts are just plain fiddly in any system - sometimes just playing with extra sections and start/end conditions will get you better results.
This document contains a couple of itterations
Hope this helps
https://cad.onshape.com/documents/8f9a97f07eb330531a392528/w/6bd39b5084aea70644f4c269/e/8acf96caf9e86aabed042a97
ps - totally fine to loft to a point, you did not need to make the tiny circle.
Thanks for the top on lofting to a point as a profile, that saves a lot of messing around. In the end the other issue I had was the paths were just not structured well enough to line everything up nicely so I redrew them and ensured the tangent constraints were there. Giving me:
I added some additional profiles to keep it cylindrical in the center and it's finally looking exactly as intended. One question I did have is how did you make the 'Selections' that are in your loft, when I use the 'Create Selection' and add them it just adds the individual items. In the end I used Composite Curves instead to create the subsets of curves to use as guides, just curious how you did that.
Thanks for the help!
Paul, I think you will find if you click the little arrow next to the selection you can expand it to select multiple selections rather than using a compound curve.
(also clears up some debate around here as to 'what the hell is that?' )
