Update a Drawing in a versioned document?
matthew_muckermatthew_mucker Member Posts: 7 ✭✭
I have a document with several tabs, including some drawings. I made a version of this document but neglected to updated my drawings before doing so. Now the dimensions in the drawing don't match the dimensions of the actual parts. Is there any way to update the versioned drawing to the dimensions of the versioned parts?
    You will have to update your drawings, then redo a new version
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,930 image
    You can always rename your old version to avoid confusion.
  • lanalana Onshape Employees Posts: 746 image
    If you've moved on on your Main branch, you can create a branch starting at the version and update the drawing on it.
