Is it possible to move (or copy) parts from one part studio to another?
mark_proulxmark_proulx Member Posts: 48 ✭✭
I imported a .stp file into a document.  The importation process created a new part studio for the contents of the .stp file.  I would like to move these parts from the new part studio to an established part studio.  Is this possible?
  • mark_proulxmark_proulx Member Posts: 48 ✭✭
    Well, that's poopy.  Thanks for responding.
  • brucebartlettbrucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,146 PRO
    If you don't want to see the part studio tab with the import in it. You can version, then link the derive to the version and delete the tab on the main. This also gives heap more speed if it's a complicated part. You kind of end up with the same result in the end.
