Spline Point Stuck to Axis
The end of your spline has a "horizontal" or "vertical" constraint to the origin. If you hover over the endpoint that is "stuck" the constraint will show up as a horizontal or vertical line (respectively) within a blue box. You can then click on this constraint and delete it with the delete key:
https://cad.onshape.com/help/Content/constraints.htm
You can also easily find this constraint by checking the "show constraints" box in the sketch dialog, then delete it the same way.
Anway, thanks.
Using shift …I would have thought holding down the shift key when you do want to attacht the point, because then it is a willful act…
