slow graphics (sometimes...)
Hello,
I am having some performance problems with rotating, panning, and zooming the 3D view (Chrome 42.0.2311.90 on MAC-OSX Mavericks). The performance varies between really fast (like local graphics) to incredibly slow. Could this be a server side problem or is it more likely a problem on my side? Today was the first day I noticed it, but I haven't been using OnShape for about ten days before. Generally I am not doing any heavy duty work -- just a few very simple 3D parts. I tried Safari and Firefox, but the problem was the same.
Best regards,
Oliver
Best regards,
Oliver
Does this happen after fully quitting chrome and restarting it? I've had issues in the past where chrome had crashed, didn't free up the memory associated with it, and caused jerky behavior until I restarted it. If that doesn't fix it, can you send us a screenshot (ctrl + u or "Feedback" in the help drop down) while modeling so we can get an idea of what the graphics look like?
The issue is worse when I am hooked up to my thunderbolt display. Issue exists in both Chrome and Safari. It has gotten so bad today that I just gave up and went back to Geomagic for this part as OS was unusable.
This should be beefy enough, right? My performance with SolidWorks in Parallels tells me so.
Last but not least, my result from speedtest.net :
(Yes, my IP is included to show that I am genuine. Have fun with it. )
So internet connection problems are ruled out too, right?
I really want this Onshape thing to work, I am always the first to embrace new technologies, even is it has to be the hard way in the early days, but in its current state, Onshape is just unusable for me...
But if I try to make any yellow box selection it still freezes the sketch (with the spinning circle), so that is still an issue.
My Mac Specs:
My internet speed test:
Anything going on at onshape that might be causing the service to moving along so slowly?
Map of the current DDoS attack:
