View Error
RamDragon03RamDragon03 Member Posts: 3
View couldn't be created due to transaction failure. When I try to make a drawing I get this Nag. and this "T18-Start_R Http::Client error: 401"
Can I fix this.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,979 image
    Are you using a supported browser? If so please report a bug.
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,015 image
    Is the url of the page start with Sso.onshape.com?  If so replace sso with cad and it should work. If not send in a support ticket under the ? Menu
  • RamDragon03RamDragon03 Member Posts: 3
    Thank you, I use Firefox and changed oss... to CAD.../url. Thank you again.
