Anyone know how to finish the thread on this Cap Head Screw, I have tried every way I can see.
cadmando
Member Posts: 68 ✭✭
See my model: Cap Head Screw. The sketch of the thread is not correct but it should work.
Many thanks in advance
Graham
Graham
3dcad
Member, OS Professional, Mentor Posts: 2,476 PRO
Found your model. Here's a copy fixed, not perfect but should give you the idea.
Graham Cap Head Screw
https://cad.onshape.com/documents/6244b47257194459bb2656be/w/7010dc34d5c842379bd412d8/e/701d71b01188475280d748e4
Another solution would be to sweep a part for thread and boolean subtract material away.
Edit: After you get this right you will possibly think how to make the end of thread 'fade away' on top. For this we need loft, which is not available yet.//rami5 -
3dcad
You can also check out @BruceBartlett 's fasteners doc. I remember Bruce figured out how to make the end of thread.
https://cad.onshape.com/documents/516b1784884d4facbc4c0d74/w/8e947edb43904354bb16b3f2/e/589eaf71321043e28046aac0
//rami5
https://cad.onshape.com/documents/9e490bf01c3f4eaa924f7b5c/w/3d4e51ed75874fbb96a49319/e/727dda98612c4074bb4c2101
Onshape is great, just learning the basics.
Graham
Graham
