How can I copy a sketch from one document and paste it into another?
chris_8chris_8 OS Professional Posts: 102 PRO
Or... can I export a sketch from one and then import it to another?
TIA
  • chris_8chris_8 OS Professional Posts: 102 PRO
    Not sure why the subject is all caps.  it wasn't when I typed it.  Weird
  • paul_1paul_1 Member Posts: 33 ✭✭
    darn.  i came to the forum just now to ask the exact same question, since i want to try a variant of a design i did before, and the "suppress" feature makes choosing between alternatives easy.  but i'd like to start from my original sketch.
    copying of various sorts is clearly a big missing piece right now.
    edited April 2015
    @pgf  You should remember that you can reuse sketch or just parts of it. So you can draw as much lines into one sketch as you wan't and if you can recognize the right ones to choose in extrude you can create multiple extrudes using different geometries of your 'master' sketch. Then use suppress just for extrudes.
