tangent and coincident constraints
wayne_pinnowwayne_pinnow Member Posts: 2
if a line has a tangent constraint to a circle, is it necessary for the endpoint of the line to also have a coincident constraint with the tangent circle?
working on master sketch of lesson 4, I find that if I delete the coincident constraint on the endpoint of the line, that point becomes blue ... adding the coincident constraint back onto the line endpoint to be coincident with the circle (already with an existing tangent constraint between line and circle) ... and now the endpoint is again black (full defined)
