issue with slide 21 of lesson 4: Exercise - Creating Multiple Parts in a Part Studio
wayne_pinnow
Member Posts: 2 ✭
on slide 21 of lesson 4: Exercise - Creating Multiple Parts in a Part Studio
I have made a copy of my file for you to examine: wrp_for-support_Exercise: Creating Multiple Parts in a Part Studio (URL below)
when I go back and attempt to edit the master sketch, I find I am not able to change the 50mm center diameter to 75mm as requested in slide 21 ... it changes the constraint diameter to .5 * (75mm) to become 37.5mm;
this also happens to the 25mm diameter at the straight end of the large arm ... when attempting to change to 45 mm as requested in slide 21, it changes the constraint diameter to .5 * (45mm) to become 22.5mm
any suggestions on what is wrong with the master sketch ...?
image below shows this after changing 25mm to 45mm (then clicking to edit again)
KatieHuffman
Member, Onshape Employees, Developers Posts: 194
@wayne_pinnow this is actually a known issue with some dimensions that we are working to fix. To finish the exercise you can delete the dimension and re-create it with the new value.5
