Bounded Planar Surface
Brian_McVeighBrian_McVeigh Member Posts: 78 PRO
The ability to create a planar surface from multiple bounding edges would be great.  At the moment this can be achieved with a Fill, but it seems like overkill for this, adding 0.5 second onto the regen time.  It can also be done, with a sketch, an extrude, and an enclose, but it'd be much tidier to have it as a 'bounded plane' feature.
    usually offseted surface with zero offset distance should manage this
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,012
    @Brian_McVeigh Now if this is done on the end of a cup shape then the offset surface with 0 offset might not do the trick unless it has a sketch face to use.  A few comments here:
    1) Fill works and best when not exactly planar..
    2) You can use offset surface at 0 but if you do not have a face to pick like a sketch then it is not as helpful .
    3) if the goal is to make a solid adding any planar surface will do untrimmed and Enclose will work.
    I would still use fill or add a sketch and use of offset.
    @Brian_McVeigh
    You could use three point plane if you wanted to use enclose (it will accept the plane)
    right any face will do
  • Brian_McVeighBrian_McVeigh Member Posts: 78 PRO
    Interesting, didn't know an untrimmed face would be enough, cheers for the tips!
