How do I draw an epitrochoid (Wankel rotary engine)
Hi there,
How can I go about drawing an epitrochiod in Onshape?
http://en.wikipedia.org/wiki/Epitrochoid
For a four-to-one ratio as per the wikipedia example:
Maybe you could model a single generatrix circle at 12o'clock on the base circle, with 3 equal length lines equally spaced radiating from its centre (draw one, then sketch pattern - Yay!)
Then sketch pattern these four elements, as a single group, twelve times round the base circle.
Draw a twelve point closed spline, snapping the control points to successive endpoints, incrementing anticlockwise around the generatrix as you travel anticlockwise around the figure.
This is all just an approximation though.
You guys probably already have this on the radar, but being able to do equation driven curves (polar & rectangular) would be nice.
