Importing STEP file
bill_daniels
Member Posts: 277 ✭✭✭
After an epic catalog search, I found the exact part I needed - a stainless push-type bulkhead elbow for 14mm hard tube and lo, a STEP and IGES CAD files are available for download. So, I downloaded the ZIP file, extracted the STEP file then imported it into Onshape. As expected, it appeared as a part tab which opened to reveal a beautiful CAD model of the elbow. I'm feeling good. Now to import it into my big assembly.
Now the strange thing. Although the part appears as a tab, it does not appear in the insert dialog box - it simply isn't there. I went back and imported the IGES file but the same thing - it isn't in the insert dialog box. What gives?
Perhaps, if Onshape would automatically check the surfaces filter on the insert dialog, it may be more obvious to folks when the part is a bunch of surfaces.
On the other hand... it may prove annoying to those who do not want to see 100 surfaces on the dialogue box just because one vendor's model sucks.
I'm not sure how to make it more apparent when models are imported with surfaces, other than a message or some other visual Que that surfaces have been imported with the model. OR will it be a brief learning forever when people don't see their parts on the import dialogue as expected.
