How do I draw an epitrochoid (Wankel rotary engine)
onshaperonshaper Member, Mentor Posts: 94 ✭✭✭
Hi there,
How can I go about drawing an epitrochiod in Onshape?
http://en.wikipedia.org/wiki/Epitrochoid
    Freehand? ;)
    @Onshaper
    For a four-to-one ratio as per the wikipedia example:
    Maybe you could model a single generatrix circle at 12o'clock on the base circle, with 3 equal length lines equally spaced
    radiating from its centre (draw one, then sketch pattern - Yay!)
    Then sketch pattern these four elements, as a single group, twelve times round the base circle.
    Draw a twelve point closed spline, snapping the control points to successive
    endpoints, incrementing anticlockwise around the generatrix as you travel anticlockwise around the figure.
  • billy2billy2 Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,099 PRO
    A spline would only approximate your curve. Maybe this is good enough.
    I would probably make two circles, one for the inner radius and one for the outer.  I'd then make a construction line from the center of the outer circle to the edge of the inner circle, place a mid-point on it.  Circular pattern this mid-point around N times about the center of the outer circle.  I would then circular pattern those patterned points about the inner circle N * inner_radius/outer_radius times.  This should give a full set (and more) of points to attach a closed spline to.
    This is all just an approximation though.
    Jake Ramsley
    Indeed, and I should perhaps have made that clear .... it probably goes without saying the approximation could be refined by increasing the number of control points
  • onshaperonshaper Member, Mentor Posts: 94 ✭✭✭
    edited April 2015
    @JakeRamsley
    You guys probably already have this on the radar, but being able to do equation driven curves (polar & rectangular) would be nice. :)
  • maxdotreynoldsmaxdotreynolds Member Posts: 2 ✭✭
    onshaper said:
    @JakeRamsley
    definitely :) it's cartesian btw..
  • mahirmahir Member, Developers Posts: 1,315 ✭✭✭✭✭
    This post is pretty old, but check out FeatureScript Parametric Curve. It does exactly this. Kind of klugey, but it gets the job done.
