Deleting points?
tj_thorniley
Member Posts: 65 ✭
NeilCooke
Moderator, Onshape Employees Posts: 5,933
Perhaps not as obvious on the mobile app. Press and hold two fingers so the box select pops up. Drag it around the point(s) to delete making sure only entities inside the box are selected then press the check mark to select them. Quick two finger tap to then bring up the delete menu.Senior Director, Technical Services, EMEA5
Make sure you've not got another feature pre-selected. eg, if you have the line tool selected and then right click on the point you will have context sensitive "line option" not the delete option.
Owen S
See:
