Drawing: How To Create a Linear Diameter Dimension?
Don_Van_ZileDon_Van_Zile Member Posts: 195 PRO
I would think there would be a way to attain this Linear Diameter Dimension style, but can't figure it out. I would think the "2 Point Linear Dimension" would give me what I wanted since the "2 Point Center Line" is the exact behavior I would expect for that dimension style (that snapping behavior is perfect); it's perfect for Center Lines! Is this a current limitation in drawings?
  • michael_mcclainmichael_mcclain Member Posts: 198 PRO
    Place a dimension anywhere so its on the page, then drag the grips to the quadrants for that dimension. I think quadrants should be valid on dimension creation, but they only seem to pick up once the dimension has already been placed.
  • Don_Van_ZileDon_Van_Zile Member Posts: 195 PRO
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,873
    @Don_Van_Zile - when the dim tool is active, press Shift + Q to activate quadrant snaps
    That's certainly a better way. I would still love the "active snapping" as shown with the 2 Point Center Line; again it's so convenient for "almost" anything.
    Just a potential UX idea for the Shift and/or Control keys etc... :)
    It used to be on by default, but it annoyed some users (apparently).
    edited September 2018
    It was FAR more annoying not knowing how to do it or that it could be done.  ;)
