Anyone drawing cabinetry?
eric_schimelpfenig
Member Posts: 75 EDU
in General
As the title says, is anyone out there using Onshape for cabinetry? If so, what's your process? Are you using it for designing spaces, or manufacture too?
So you code everything manually for the most part? Yikes
Why bother modeling it then, just go to paper an pencil
Sometimes we create 3d models from dxfs exported from cnc
We model because we wan't to see the design before production, check interfere, render product images, create assembly instructions and avoid manual calculation of things. We do not model for cnc.
Today's woodworking machinery are so easy to program that it's only matter of few minutes (way faster than Onshape sketcher). And we use macros for standard stuff, environmental & global variables to keep programs easy to update on hardware changes and sometimes combine programs using if-clauses and variables accessible from worklist to quickly select different 'configuration' for drilling.
But note that we mostly produce our own standard models in reasonable batches repeating time after time, it's completely different story in batch size 1 production where few minutes programming per piece makes huge difference.
@MecSoft_Support
I will certainly give it a try! Do you support European woodworking machines like Homag, Biesse, Scm etc.?
