Mirror in assembly
Hi
I'm trying to mirror a part in assembly but can see how. I've tried mirroring in part studio but cant separate it from the original or delete the original
Any help would be appreciated. Thanks
    stuart_hatherwaystuart_hatherway Member Posts: 8
    Thank you Mike.
    That's worked,I hadn't noticed but as i was selecting the mirror plane the part mirror was jumping from NEW to ADD!. I want both parts but as separate drawings as I need to further modify only one.
    Thanks again
    edited September 2018
    Hi and welcome.
    Please have a scan through of this first:-
    Af first glance it sounds like you're doing a mirror "add" rather than "new" but it's impossible to help without a little more info.
    Cheers,
    Thank you Owen for coming back to me so quickly. I was using Mirror new selecting the part as entities to mirror and selecting an end face for the plane. I have a part that i have designed and need a separate part that is a mirrored version. If I've read up to date this cant be done at the assembly stage and has to be done in the part studio. Is there a simple way of mirroring the part without keeping the original. If you hadn't guessed I'm new to 3D cad
    Regards Stuart
    Thank you Mike.
    Thanks again
    billy2billy2 Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,014 PRO
    @stuart_ward055 I took a stab at it using @mthiesmeyer approach:
    I'm doing everything in a part studio:
    Here's the assy:
    I'm not sure what you're trying to do. I'm wondering if you should be working in a part studio and forget about the assembly for now.
    In OS, parts that relate to one another should be done in a part studio. Part studio = many parts.
    In OS, assys allow your parts to move & instancing (bolts should be instanced). Eventually everything will end up in an assy, but at your chassis level, I'd stick to the part studio.
    I'm probably wrong......
    Thank you for your input
    ron_thatcherron_thatcher Member Posts: 1
    As with evaluating all new CAD systems, I eventually stumble across a limitation that makes the tool useless in order for me to be efficient, and this is one of them. In the other 2 systems I use.. I use mirror and pattern in assemblies all of the time. I would not be able to do my job without this. See you in a few years On-Shape..
    steve_shubinsteve_shubin Member Posts: 1,068 ✭✭✭✭
    edited November 2020
    ron_thatcher said:
    ... I use mirror and pattern in assemblies all of the time. I would not be able to do my job without this.
    Linear and circular pattern are in assembly In Onshape
    Now about Mirror. Yeah it would be more convenient. I’m sure there’s some here in Onshape that would like it in assembly. But in the mean time, you can get to it via In-Context Editing fairly fast
    alnisalnis Member, Developers Posts: 449 EDU
    Honestly, in my experience working on some projects in SolidWorks for university, while the assembly mirror feature is nice, there are just so many other assembly workflows that are slower and less efficient that I really prefer working on any assembly in Onshape. Pretty much any speed decrease from not having a mirror command is more than made up for with snapping custom parts with mate connectors and the replicate tool. Assembly mirroring would be nice, but I haven't found a case where it really hurts to not have it.
    Student at University of Washington | Get in touch: contact@alnis.dev | My personal site: https://alnis.dev
