Mirror in assembly
stuart_hatherway
Member Posts: 8 ✭
Hi
I'm trying to mirror a part in assembly but can see how. I've tried mirroring in part studio but cant separate it from the original or delete the original
Any help would be appreciated. Thanks
mthiesmeyer
Onshape Employees Posts: 115
Hi Stuart,
I'm not quite sure if this is what you're looking for, but I took a stab at what you described here. I mirrored the part in the part studio and then used the `Delete part` command to remove the original. Can you explain why if you wanted the mirrored part, but not the original, you didn't model the original part in the mirrored orientation?
Thanks,
Mike5 -
stuart_hatherway
Member Posts: 8 ✭
Thank you Mike.That's worked,I hadn't noticed but as i was selecting the mirror plane the part mirror was jumping from NEW to ADD!. I want both parts but as separate drawings as I need to further modify only one.Thanks again0
Thanks,
Mike
I'm doing everything in a part studio:
Here's the assy:
I'm not sure what you're trying to do. I'm wondering if you should be working in a part studio and forget about the assembly for now.
In OS, parts that relate to one another should be done in a part studio. Part studio = many parts.
In OS, assys allow your parts to move & instancing (bolts should be instanced). Eventually everything will end up in an assy, but at your chassis level, I'd stick to the part studio.
I'm probably wrong......
Now about Mirror. Yeah it would be more convenient. I’m sure there’s some here in Onshape that would like it in assembly. But in the mean time, you can get to it via In-Context Editing fairly fast
