STEP file import from Altium
anthony_schanzle
Member Posts: 2 ✭
I have a PCB done in Altium Designer than has been exported to a STEP file. When I Import it into Onshape, only one part is shown. I can open the STEP file in FreeCAD and Solidworks.
1. Checking the "flatten to part studio" option during import.
2. Export the STEP file from SolidWorks to see if that works or not and let us know.
Hey Neil I tried that it doesn't work. The fact is multiple people are struggling to import .step files from a common PCB program called Altium The app that costed money and solved this called PCB Fix is also gone. What do you suggest?
See my post here: https://forum.onshape.com/discussion/comment/45091/#Comment_45091
Basically the problem is with the STEP export from Altium. The files have problems in SolidWorks as well - at least for us.
