spaceclaim
walter
Member Posts: 41 EDU
how can one upload a spaceclaim file
cyclonewade
OS Professional, Mentor, Developers Posts: 53 ✭✭✭
Hi Walter,
Technically, any file can be uploaded into Onshape, Onshape documents are awesome containers. However, Onshape can upload and TRANSLATE a wide variety of industry standard CAD formats. The complete list resides here.
https://cad.onshape.com/help/#web-help/translation.htm?TocPath=Up%2FDownload%20and%20Translation|_____4
Unfortunately, SC does not appear to be a file format that Onshape can natively read. Your next best option is to go with a "neutral" file format, such as parasolid, iges, acis or step. Once the neutral file has been created from SC, upload and translate with Onshape.
Good Luck!
Wadeimagine.create.deliver5 -
paul_chastell
Onshape Employees Posts: 126
I'd suggest trying ACIS first (.sat). It is the kernel used by spaceclaim and therefore will incur less loss in translation, as a single hop from ACIS to Parasolid. Or, if their Parasolid export is better than our Acis import, Parasolid export from spaceclaim may work better. Anyone have specific experience of whether either is better?Paul Chastell
TVP, Onshape R&D5 -
onshaper
Member, Mentor Posts: 94 ✭✭✭
As a general rule I use DXF for flats, STEP for 3d solids, and STL for tessellated surfaces!
5
Good Luck!
Wade
TVP, Onshape R&D
file to , that will work good in onshape?
Wade
Recently tried to export parasolid from Ons to Keyshot and it failed to open, tried step and it was good.
