imported assemblies not constrained
scott_seifert396
Member Posts: 2 EDU
Parts in assemblies that I've imported from McMaster Carr and others my boss has created are not mated to one another once I get them into an assembly document. The components "pull apart" as I move them about to mate them to other components in the assembly. What am I missing?
owen_sparks
Member, Developers Posts: 2,660 PRO
You're not missing anything. Imported parts (in any cad system, not just Onshape) are dumb solids. They will need to be grouped or mated as required.The mating method is different for different types of CAD so there is no universal assembly file type for a supplier to export as, for us to then import...Solids, no problem. Mostly.Cheers,Owen S.Business Systems and Configuration Controller
HWM-Water Ltd8
