Unable to Use New "Scale Uniformly" Feature
Steve Trambert
Member Posts: 5 ✭
I read in this blog post that OnShape had introduced a scale feature: https://www.onshape.com/cad-blog/whats-new-in-onshape-apr-22-15
I am trying to use that feature in the model that I'm currently working on, but it's not showing up as one of the drop-down options in the "Transform" dialog. I am, however, seeing the new comment bubble for sharing comments, which I understand to be part of the same update.
Any advice for how to resolve this? Is the scale feature delayed? Or is it only available in parts created after the feature was introduced?
Thanks in advance.
Thanks in advance.
lougallo
Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016
@R.Paul Send me feedback from the document (Open the document and hit CTRL U) and explain that you cannot access Transform then share it with support (you can hit the SHARE button and at the bottom of the pop up there is a link "Share with Onshape support") I can take a look at it. The document might have not upgraded and I can check. That is what fixed @Steve TrambertLou Gallo / PD/UX - Support - Community / Onshape, Inc.5
@Lou Gallo, I have spotted a similar thing. In one of my documents, in one Part Studio, the Transform>Scale option is not available but in a newer Part Studio, in the same document. In one earlier document, I tried, the Scale option was available and worked?
