Imported Part name to match the sldprt part file name in Solidworks
Hi all
So when I import Solidworks files into Onshape, there is one problem I always encounter. When I import a sldprt part file, Onshape tends to name the part studio the same as the part file name, but the name of the part is some random name like Part1. This makes it difficult to identify the part if it is used in another assembly. I know this problem doesn't arise when I pack and go the assembly into a zip file and import. But there are few shared components which I would want to import as individual part studios and not as part of an assembly. If Onshape made it possible to automatically name it's part names as those in SolidWorks, that would be great.
P.S: When I import a part named examplepart from Solidworks into Onshape, the name is carried over as examplepart.sldprt . I'm assuming this is unwanted and most of us would just want it to be renamed as examplepart without the extension name. I don't know if there is an explanation to why the name works like that but if there's no difficulty, it would be nice to have part names as just the file names without it's extension name.
Thanks
Thanks
4
