How do we export a DXF or STL file to a memory stick?
Export DXF or STL Files
wolf_starke
Member Posts: 1 ✭✭
Right click on a part studio tab and export to STL.
Onshape will drop it in your browser download directory as the document name.
To get it on to your memory stick move from the move from downloads directory as per usual. No way to specify directory in Onshape when exporting.
Ctrl+j on Chrome brings up a download list which is also handy.
Offtopic:
I switched to Firefox because mouse roll didn't scroll feature tree nor parts list. Also zooming is faster (better) in firefox, I even tried some addon in Chrome to make it faster but didn't work in Onshape.
the fastest way to jump through folders/directories and files is to use Listary
I found it a few weeks ago and I will never miss it. If you search a file on your PC, Listary will find it. (as powerful as Google Desktop was)
If you want to safe a file in a special folder, you can add it to favorites of listary and jump directly into the folder with one click and not a click from one folder to the next.
It only works on windows.
This is not an advertisment for the software! I really like it and I think it could help others as it helps me to do my daily job faster
best regards
martin
