Point Pattern Feature Script
Kat_ElyKat_Ely Member Posts: 2 PRO
Hi,
I'm having issues with Point Pattern Custom Feature where for the last two days when I've logged on in the am the CF has disappeared from my toolbar. Each time I re-add it to my toolbar and then it breaks every instance of Point Pattern that I have. You can see that right now on the part studio CHASSIS UPPER SHELF. If you could help me resolve this that'd be great.
Thanks,
Kat
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,925 image
    Hi @Kat_Ely - it is likely that, when you are adding the Point Pattern FS to your toolbar, you are not selecting the same document. There are many copies that people have made, so just make sure you select the right one by navigating through the "samples":
    Having said that, just adding a feature to your toolbar should not break any existing features, nor should it disappear. Also, check that your browser is wide enough to display the icon on the actual toolbar and it is not hidden under a dropdown like this:
