Need help with sheet metal tab feature - will not generate in this part
center_impact
Member Posts: 6 ✭✭
I use the tab feature every so often, I usually draw a sketch attached to a sheet metal part and then click the tab feature to turn that sketch into an extension of my sheet metal part. For some reason in my model im currently working on the tab will not generate and I dont know why
If someone can help me understand what I am doing wrong i
would greatly appreciate it
lana
Onshape Employees Posts: 746
You can roll back to see how the model was built. In short : I moved Sketch 11 to before Sketch 5, modified Sketch 5 to reflect the shape of the base you are looking to build and used Sketch 5 in Start sheet metal 2.
You can merge Onshape support workspace into Main and continue from that state.
6
