INTERFERENCE DETECTION
Member Posts: 1 PRO
Hello,
is there a tool for  Interference Detection in On-Shape similar to the one in SolidWorks ?
«1
  • Member, Developers Posts: 2,660 PRO
    Not yet.  But things are developing quite quickly.
  • Member Posts: 265 ✭✭✭
    edited October 2016
    @Maxi At present the available interference detection is not exact as in Solidworks but as a work around you can see the interference in section tool itself. Areas which are intersected are highlighted in red color. You just need to turn the section view on from small cube below the bigger view cube and then drag the manipulator arrows to see the section and interference if any.
  • Member, Developers Posts: 619 ✭✭✭✭
    edited October 2016
    @Maxi, User can check interference by activating section view from right clicking on view cube. User cannot see amount of intersection from this tool.
  • Member, Moderator, Onshape Employees Posts: 315
    As others have said, there is currently no support for interference detection, though it is definitely on the roadmap!
    Onshape, Inc.
  • Member Posts: 137 PRO
    That's a long road map! Its been two years since the post was made.
    Here is an example of some interference and what I do.
    Use section views and keep editing it. You must save the view or it shows the face as orange and you don't notice the red interference. That's the first image.  In the second image, its a closer look but you will notice the interference is in a different shade of orange.  In the third image, I've saved the section view. Now you can see it in red.  It is a lot of work!
  • Member, Developers Posts: 3,944 PRO
    to be honest, a separate interference detection is a waste of time. The section tool is lightning fast and accomplishes the same thing.
    I haven't used ID (tried it a few times in SW, but it usually is a long list of fasteners) Found it much easier to pay attention to what i was doing the first time ;p jk
    But really, it is a pretty clear image even looking at that photo on a cell phone screen. What else do you need it to do? Should the section view draw a large red circle around those also?
    Maybe it could me an opiton to turn the circles on and off from the plane selection window?
    edited October 2018
    I wonder if it could be as simple as a Boolean subtraction loop of every part from every other part and see if the mass changes?  ICE, copy in place, featurescript, done. Nothing visual need just an output if ok or interference detected.
    Would then need to determine where the interference was. Similar loop with Boolean intersection loop? Show the ghosted ice view with the solid intersection parts under it and we can see the locations of the interference.
    O.S.
  • Onshape Employees, Developers, HDM Posts: 1,230
    @owen_sparks
    Something like this?  https://cad.onshape.com/documents/2ee680cb5e9314e2b06e9f94/v/547b09709575a33c24a3c5f0/e/7b52f0ffc178ad83f6810685
    To use, just create a new part studio in-context, add this feature, and select all bodies.  Also works in a part studio without in-context stuff.
    I'm not sure what the best UX is -- how to report interference, what to leave, etc. -- this is just a guess (i.e., this feature deletes all bodies that don't interfere) so I'm looking for improvement ideas.
    edited October 2018
    Howdy @ilya_baran
    Firstly let me ask you a question? Was this fun?
    If yes, then OK, otherwise please ignore anything I say at the weekend, you folks deserve a break!  :)
    Nope, not something like that, exactly that, that's perfect! In 100 lines of FS you've created a feature that is useful today.  B)
    OK. suggestions...
    Before PT was kind enough to visit I'd have come up with ideas that would take a dept. a month to write, so I'll limit to stuff that is achievable and can be iterated upon.  I'm trying to think of stuff now that can be built with existing tools, or small additions to them, not blue sky stuff.
    Short term improvements:-
    (a) Option one is don't change a thing, this is useful today exactly as it stands.
    (b) Name the new bodies something helpful, like "interference Solid", and perhaps the name of at least one of the original parts that it was created from.
    I wasn't thinking big enough.  Now you've done the finding it can also be used for the fixing!  Squirt the new bodies back to the assy, another ICE to boolean them away from whatever part caused the interference and you've not only found the interference but you've fixed it too!!
    Mid term improvements:-
    (c) We have a part property "Exclude from BOM", I propose a similar one "Exclude from Interference Checker" that will allow us to suppress false positives from stuff that is meant to interfere. Standard content comes to mind.  This would have a checkbox in the feature UI as we might want to show that interference after all, to see we have the right size bolts for example.  Perhaps show "expected" interference in green solids and unexpected in red?
    Long Term:-
    (d) Add an icon to the or right click option in the assy to create the new ICE studio, call the FS and populate it with all the parts from the assy. (old topic so I won't bang on about it but we want an "add everything when you rebuild option" not just a "add the part I clicked on when i first ran the feature" option.  A bit like adding a live part studio to an assembly not just what was in it when we first clicked on it.)
    (e) Be able to accept contexts as a parameter of the feature.  Thinking of the folding step stool example used in your webinars...  We have one context for open, one for closed and feed them both into your feature.  This creates the solids to subtract from the tubes to allow it to fully open or close without any sketching, extruding etc and it's still fully parametric.  This is so cooool!
    (f) Get some sleep.
    (g) OK getting carried away now. Perhaps have it automatically run as a background process in any new assy built, with a screen indication if there is interference?
     Right, enough waffle from me, I'll just say thank you again, and leave you in peace for a while.
    Cheers,
    edited October 2018
    One more for the long term integration, expanding on the "Exclude from Interference Checker part property".  Better make that a face property, not a part property.  We want the shaft of a bolt to interfere, but not the head, or the end to bottom out.
    Just goes to show that there is no problem that can't be made more complicated by thinking about it.
    Cheers,
    O.S.
    That's a cool script.   Wish that would work for sheetmetal and in assemblies.  Hopefully something we will see in Onshape one of these days.
    edited October 2018
    @AuroraRon
    Good news, it does, and you can  :):smile:
    https://cad.onshape.com/documents/e6714096ca4b2697b60a4fa8/w/179874f12c9ade40d5dd8880/e/3f26f4443eab2dd764d2577b
    At least from the assembly.  I couldn't get it to cooperate from an active, finished, or copied in place sheet metal part, but from the assembly all was good :+1:
    Cheers, Owen S.
  • Member, Developers Posts: 144 ✭✭✭
    I can't open this @owen_sparks, is it public?
    edited October 2018
    Can you have a look,   https://cad.onshape.com/documents/91068b2c49a15b3458a5f687/w/4b32fbed070672ff1aef4ac1/e/3008655d9f8ad92ff4968d95
    I don't see how to add the script in an assembly, what am I missing please.
    Your example works and its amazing.  Very nice, thanks!
    Hi @AuroraRon, the script works in a partstudio, but that partstudio is an in context edit of the assembly. Does that make sense? If not I'll have a look at your file in the morning (Nearly midnight in the UK so of to bed...)
    Cheers Owen S.
    jeez, if anyone has a spare memory I can borrow that'd be great!!
    Cheers Owen S.
    So in an assembly I can right click one part and edit it in context. There I can add the Interference Check feature script. But selecting the only part I can, results in an error because "active sheet metal models are not allowed"
  • Member, OS Professional, Developers Posts: 2,055 ✭✭✭✭✭
    @AuroraRon
    Use the create part studio in context toolbar button
    edited October 2018
    Then add all the parts to Ilya's feature that you want to check interference between, not just one.
    Or select "All parts" on @Jake_Rosenfeld's feature
    Got it. Thank you everyone, it works fine now.
    What an incredibly useful feature.  Well done!
    Glad you're sorted out.
    Thanks for the great feedback!  A couple of things:
    V3 should work on sheet metal also and parts are named "Interference volume" -- naming them in terms of other parts is not possible with FS changes alone because FS can't access current part names.  For the same reason "excluding" is not easy to add based on properties.
    For exclusion, that's why I made it selection-based, so you could just not select it, or you could have a custom feature tag stuff with attributes...  Neither is ideal.  I'll think about this further.
    I totally forgot that Jake wrote a similar feature a few months ago -- https://cad.onshape.com/documents/4ef9d7bf5c04de6c159e6fb0/w/50103cbdb65f20d04d6f68f1/e/8dba900c665b639f1b1bab53 with slightly different design decisions.
    Finally, please keep in mind that this is a workaround -- we intend to have a more native interference checking solution in the future.
    Even more finally, of course this is fun! -- the whole point of being at Onshape is getting to improve everyone's design experience.  Quick solutions to unblock useful workflows (like this) are very satisfying.
    Very nice @ilya_baran; works as advertised on active or finished sheet metal. :+1: thanks for the update.
    Final suggestion I'd have is if one deselects both "Show colliding bodies" and "Show intersections" then the feature regenerates but doesn't give any indication that there is interference.  (Dumb operator usage I grant you but still possible.)  I might change the check boxes to a pick list with show one, show the other or show both options.
    Final, final suggestion:  Typo in the feature name, it's currently an "interfence checker" not an "interference checker"
    annotation { "Feature Type Name" : "Interefence Check" }
    Final, final, final suggestion:-  Does a FS have access to the name of the feature?  Presuming we have a feature in our tree called "Interference Check 1" can it change it's name based on the result to "Interference Check 1 - PASSED" or "Interference Check 1 - FAILED" based on the result?
    Cheers,
    Here's a suggestion.  How about adding a tolerance value?   Not only is contact in the assembly important so is tolerance. It would be just as helpful if we could see it.  Having that would be sweat :-)
    @owen_sparks
    So V4 fixes the typo you pointed out.  Rather than renaming the feature automatically (which could be done somewhat, but has drawbacks, such as the user wouldn't be able to rename the feature manually) and rather than doing a dropdown, I added another option, to warn if interference is found -- the feature turns orange if that option is checked and a collision is detected.  If none of the checkboxes are checked (i.e., the operator error you described that could cause interference to be missed) the feature errors, turning red.
