Is it possible to get the intersection shape of a sketch plane and a solid which is passes through
Omer
Member Posts: 5 ✭
I need to get the intersection info. Projection is not working for me. I also tried to use coincident tool with a corner in the sketch and a line on the solid but did not manage to get them together. Are these supposed to work for this purpose?
abefeldman Member Posts: 166 ✭✭✭@Omer - we aren't currently able to project the intersection of a plane and a surface, but based on your image it looks like you'd be able to use the Pierce constraint to attach the sketch corner to the edge of your solid. Check out the attached gif and let us know if that helps.Abe Feldman
UX/PD/Community Support1 -
cyclonewade OS Professional, Mentor, Developers Posts: 53 ✭✭✭Could you not also use the split command and the plane? Once the split occurs you would could "USE" the edges for the sketch geometry on the flat face created by the split.imagine.create.deliver1
I think it does us no harm to spend some time in an environment which, while superficially impoverished, is actually a lot richer than it looks ... richer, that is, provided we dig a bit deeper into the innate reserves of resourcefulness which modern life, and convenience/consumption culture, are doing their best to breed out of us.
I encourage all of our users to be creative with our tools and figure out shortcuts in their workflows. Just because we designed a feature with certain workflows in mind doesn't mean we didn't miss any possibilities.
