Does mirrored geometry have fixed constraints?
I am trying to make a spur gear model, using configuration variables for module, pressure angle and number of teeth. The problem I am facing with is the mirroring of the involute curve in the sketch. If I don't have any mirrored geometry, the sketch regenerates corectly, when I modify the number of teeth, but if I mirror the involute in the sketch, that geometry stays fixed, for a different value for the number of teeth.
Here is the link to the model:
NeilCooke
Moderator, Onshape Employees Posts: 5,991
@Bogdan - this looks like a bug - please "report a bug" from the help menu.
BTW the Spur Gear custom feature is calculated from standard gear equations. If you think the geometry is wrong please let me know and I will fix it.
Senior Director, Technical Services, EMEA6
https://cad.onshape.com/documents/5742c8cde4b06c68b362d748/v/16a222adf3cb9a3b33ed9536/e/c72760543a0d4412e72f6d38#_ga=2.210257941.1085763189.1540815032-1552844877.1526996123
When I set teeth to 21, then delete this constraint and put it back where it belongs, it works.
I didn't see any horizontal or anything else that limits rotation. but this mate seems to have fixed it once replaced.
https://cad.onshape.com/documents/4a9b76816517425e9badd681/w/71929366e98828276d17a511/e/f7d438af547bc8de2e0e5b69
and michael was just trying to help. No need to be like that
