What's the best way to model standard aluminum extrusion in Onshape?
I want to make a model with standard 2020 aluminum extrusion, with T or V slot, like this:
I'm new to Onshape though, and I can't seem to find it in any standard parts. I found a few forum threads from a long time ago but they seemed to be workarounds.
Is there some good way of doing this, or would I have to design the part myself? thanks!
You can also use the Beams custom feature to make your frame - see video here: https://forum.onshape.com/discussion/9963/improvements-to-onshape-august-20th-2018#latest
or
If not, it seems like they might be easy enough for me to make manually. Thanks again for the great tool!
You will need to create your own library of fasteners separately.
https://appstore.onshape.com/apps/Content/KAMXGDNGLR7APEHQNTPRS2CFEMW5AZL7JZG542I=/description
Onshape, Inc.
