Revolve problem
mischl
Member Posts: 28 ✭✭
hi there
is anyone able to see why this is going wrong?
my only hint is that if I choose add, these deviations are visible between the two parts, looking that not both have the same arc resolution. perhaps it is only a render problem...
document: https://cad.onshape.com/documents/6be47f5f723c794b41ebf8d5/w/ea3952b761510d13651a6397/e/0c912ba664c080be611127a3
thanks in advance
thanks in advance
NeilCooke
Moderator, Onshape Employees Posts: 5,995
You are trying to mix revolves and extrudes - Extrude 4 creates a very small edge at the front which is probably the issue. Stick to revolves if you can.Senior Director, Technical Services, EMEA5
but it does not help to do the revolve properly to merge with the other part (part 1)
