How to enable default setting for subtitle and speed for tutorial videos?
anugrahandianugrahandi Member Posts: 2 PRO
Like in the title, how to enable default setting for subtitle and speed for tutorial videos?
Because I moving from other cad system, i need to watch all tutorial to get a good grasp. However, I can't change default for videos subtitle and speed.
Do I need to change my browser setting? if I use youtube, usually it set the default to the last setting.
Thanks,
Andi
  • bradley_saulnbradley_sauln Moderator, Onshape Employees, Developers Posts: 266
    Are you talking about the self-paced training videos or the instructor-led recorded training?
    The self-paced courses in our learning center have this built-in:
    This is definitely the recommended way to go when moving to Onshape from another CAD system. We also have instructor-led training under the learning center that you can sign up for as well (I'm not sure if the recordings have these options @KatieHuffman)
    The section you might be looking at is from our website video library which houses all of our live recorded content like webinars that may cover some training information: https://www.onshape.com/videos/. These videos will only have the option to change video speed under the gear icon on the right.
    Twitter: @bradleysauln
  • KatieHuffmanKatieHuffman Member, Onshape Employees, Developers Posts: 68
    You can turn on the close captions in English and adjust the speed with the gear for all videos in the Learning Center. I do not believe there is a way to make that a default option as you begin another video.
