List part numbers in search results
I started playing around with part number generation when I decided to see what part numbers had already been assigned somewhere and realized I couldn't figure out which parts already had numbers and which numbers have been used already.
It would be great if I could:
https://forum.onshape.com/discussion/comment/40035#Comment_40035
- See a list of part numbers that have been assigned for my company, OR
- See part numbers displayed in search results (I think this would work because I think I can make a search just return all parts that I have).
I understand the database structure of Onshape uses specific identifiers behind the scenes to be able to link all of the parts/assemblies/documents together in a smart way. Therefore, the names of parts, part studios, assemblies, and drawings DO NOT have to be unique, and there are few restrictions on naming. This is all fine when working inside of Onshape.
The problem, however, arises when I need to uniquely identify a part, assembly, or drawing in a system outside of Onshape, such as purchasing or manufacturing systems. The standard method for identifying these things is the Part Number, but Onshape part numbers are buried in the part meta data and the only way to find or verify a part number is to look at individual assemblies or drill down into part properties. From this perspective, it seems having a simple way to view which part numbers are assigned (at a company level?) and as well as names/descriptions for each part number would be a great way to make sure everything is correct.
I think displaying part numbers (and possibly other user-selected properties) in search results would be a big step in the right direction.
Being able to actually see what the part numbers are in the search results would make that much more useful. I've been trying to put part numbers in my part names, but it would be huge (if only for peace of mind) to have visibility of the properties that are actually driving things (like part numbers and revisions) without having to look in an assembly BOM or dig into part properties one at a time.
