Collision in the bending part
hobie_smith
Member Posts: 35 ✭✭
Hello,
I want to move on this part of the two open edges so far that the tips meet on the outside.
These are abraded after laser cutting so that the seam can be welded without adding material.
Is there a way to cancel or ignore the collision to produce the part despite "error"?
https://cad.onshape.com/documents/0164e801f7167a0a3eb81116/w/b3e4f69ec8ffda53a3cef237/e/a55fe9de03020f088752ec94
Greetings Hobie
Greetings Hobie
Überstezt with Google
john_mcclary
Member, Developers Posts: 4,035 PRO
Add this to your tool bar:
Flatten without redundant edges:
https://cad.onshape.com/documents/d075777b23239493791a6871/v/3a17d545652276fcd92ed873/e/dba9566c2dda32a29752e76b
Then do the following:
https://www.youtube.com/watch?v=Zg1z7TrPawU
5
If you just have a flat pattern with bend lines that you want to fold, you can use this feature to fold it:
https://cad.onshape.com/documents/9f116620b0f6d04445f57293
The credit goes to @ilya_baran
